Old Mar 26, 2021 | 09:53 PM
DHS's Avatar
DHS
Default Re: Brighter headlight
So I put in the 100 watt bulb on the left high beam, used the Hella Optilux H7, will try that for a while and see how the wiring holds up. Since the high beams are used off and on it should not be as demanding as in the low beam light continuous use.
i got some Morimoto HIDs but you need to do a lot of wiring and I have held off on using them, although using them in the low beam should be OK, but some say HIDs do not like being cycled a lot.
