dedwards0323
The engines in these cars are "rock solid" if the routine maintenance has been done consistently throughout the years along with normal wear & tear. To comply with factory recommendations, either one of the grades would be applicable, my opinion. With the mileage you're stating on your car, I would probably lean towards the 5w40 version - that's just me talking out loud. Both oils would provide the same level of protection & lubrication at normal engine operating temperatures. The 5w40 version would give your some added protection (increased viscosity & potential lubricity) at start-up & engine warm-up period considering the mileage on the engine which could have increased tolerances ever so slightly over the years.
Parts are made to sizes which have tolerances, when used for some time the parts can exceed the original tolerances and that is called wear
at this point the parts are out of tolerance.
Do not confuse tolerance with wear.
