Old Apr 15, 2021 | 10:48 AM
waxhell's Avatar
waxhell
Default Re: SRT-6 Muffler and Resonator Delete
Originally Posted by amx1397
the muffler does not cut the noise that much,, the res is the biggest weight removable, can't see your rims but the stock rims are 26 to 30 lbs ea. the seats are 75 ibs but i guess u already know that good luck, any thing i can do to help let me know ,, i went to complete adjustable rear suspension removed about 10 to 15 lbs ,good luck
That's part of the reason (the other reason is that rubber is cheaper as well in the smaller sizes) why I went down to 17s in the front and 18s in the back. 21.6lb front wheels and 22.0lb rear wheels (but I did have to add a spacer to keep the offset close to stock). The rotational weight savings is actually substantially higher. I didn't spring for the lightest wheels out there, but looked for light wheels that were a decent price. They're also mismatched as it was almost impossible to find matching wheels in both 17x7.5 and 18x9, but I made sure that the paint color was the same (and the look actually isn't bad at all).
Between wheels and exhaust, that's about all I can do for weight savings to stay within my autocross class.
Thanks for your input!
