Old Apr 21, 2021 | 12:17 PM
Jack G's Avatar
Jack G
Default Hi Beam Flashing Mode Not Working
The hi beam on/off switch on the steering column does not turn on the hi beams when the turn signal lever is pulled up or pushed down. The lever does turn on the hi beams however, when the lo beam headlight switch is in the on position. The blue hi beam icon is also displayed on the dash. Could this be a switch related problem or a blown fuse?
