Old Apr 21, 2021 | 02:31 PM
Jack G's Avatar
Jack G
Default Re: Hi Beam Flashing Mode Not Working
I am not expecting the hi beams to be controlled to turn on and stay on when the light switch is off. I want to be able to flash my hi beams when the switch is off. As previously indicated the hi beams work normally when the light switch is on lo beam. The flashing mode is mentioned in the operators manual. I also drive an E class Benz that has the same type of light switching.
