pizzaguy
You are hearing a beep because you are not putting the top down manually correctly; you are not completing the cycle.
The reason pushing the button fixes it, is because pushing the button completes the cycle.
Are you locking the tonnaue lid? (I can never remember how to spell that...)
Pizzaguy knows.
I was in your same situation a couple of years ago. I was manually putting the top up and down until I figured out that the two main lifting cylinders were leaking. I had TopHydraulics rebuild just those two and it worked great. I haven't had any trouble since then and I had completely forgotten many of the same issues that you're talking about when manually raising and lowering the top.
Looking back at a post I made in 2018, I said:
I have been leaving the engine on when moving the top up and down. As PizzaGuy says, it keeps the control system for the top knowing where the top is. I used to move the top up or down with the engine off and eventually, the control system got mixed up and I had to re-sync it.
I've added one more step to the manual process. After I finish the up or down process, I turn the engine off. I leave the engine off for two minutes. That seems to be the amount of time it takes the control system to go to sleep and the light on the power-up-power-down switch to go out. Once it goes out, (and it always seems to be right at two minutes), then it stays off after I start the engine up. I don't get any beeping at all following that system.
That might be worth a try. I don't know why it worked for me.
The other two questions:
1. Are you manually raising and lowering the top with the engine on?
2. Have you tried re-syncing the top following Pizzaguy's process of doing three complete cycles of raising and lowering the top with the engine on?
