Thread: rear end ratio
Old Sep 15, 2006 | 08:29 PM
HDDP's Avatar
HDDP
Default Re: rear end ratio
Originally Posted by stryfox
I have looked into this about a year ago...no luck.
Berg werks use to make gears for the slk but the went under.
HDDP did some serious searching also and the best solution was to have a set made which i believe was around $3,000 and that does not address any computer problems that may arise from the swap.
Good luck and post if you learn any new info as I WANT GEARS!
Thanks.
Actually, I had a scheduled install at BergWerks for a 3.87:1 and then went to the shop and it was DOA. The owner has since gone back to work for a local LA MB dealership...
