Old Apr 22, 2021 | 10:25 AM
  #53 (permalink)
Fla_Xfire_SRT's Avatar
Fla_Xfire_SRT
Default Re: The Chevy Vega - '74 GT
~ Cough was neither the "Rona" or tight valves, ...can you say ..plug wires 3 and 5 mixed up causing backfire shifting the JEGS starter whos JEGS supplied bolts were smaller in diameter than the stock GM bolts taking out 3 separate(120degrees?) flywheel teeth. Starts and runs great so far...no dead spots starting...I think I'll live with it till it causes a problem.
~ Mounting the cluster and dash pad next then securing the steering column.
~ Problems bleeding the hydraulic throw out bearing may cause us to have to go in and shim it more....sux.
