Intake air through supercharger
Apr 22, 2021 | 10:51 AM
permalink
ku95
Feb 2018
44
S.korea
Re: Intake air through supercharger
Quote:
dinasrt
Is that a gold ceramic thermal coated charge air cooler I see in the lower left corner? Out of curiosity, did you have a leak, and is the reason why you tore down the S.C.? Nice job on the cleanup. A good time to port/gasket match/and polish up the runners, if you haven't already done so.
Yes. It is 3-years old speedriven's charge air cooler, not coated but wraped insulation tape. The reason I tore down S.C is oil leakage behind clutch. It's because of old rubber seal at snout. I found bearing is not good also, so I replaced all without snout bearing.(Snout bearing was ok)
Thanks.
ku95
View Public Profile
Send a private message to ku95
Find all posts by ku95
