Old May 10, 2021 | 02:31 PM
onehundred80
Default Re: Trunk Light On all the time
I think that may be the problem, to the best of my eleven year experience with Crossfires, no cars were built with two position switches - I'm starting to think the switch is broken. If you look at Ala_xfire's post, you will see that this all goes back to that stupid switch.
In the normal course, the trunk and interior lights operate together - I'm thinking the switch is broken internally and the trunk light is permanently grounded by the bad switch.
The slide switch only has two positions, in one position the map and trunk lights stay OFF when the doors or trunk are opened and in the other position those lights come on when the doors or trunk are opened.
Those same lights can be operated by the switch between the map lights.
