Old May 10, 2021 | 02:37 PM
Coedfan's Avatar
Coedfan
Default Re: Problems Crysler Crossfire
I have reset the remote fob several times to no effect. I put an OPD analyser in and there is no engine code showing. The management engine light goes out when it cranks and it turns over but just will not start. I read a thread which said that if the battery had been disconnected for some time the RCM can fail and the doors will not open/close on the remote but i cannot see how this could be the case but it would explain if it is a defective RCM (which looked brand new but I did see some dulling on the crucial terminals at the top (3 of them). RCM was replaced 2012. The battery charge shows nearly 14 across the terminals (13.7) and I was advised as the starter operates normally it would not be the security key module. So I am really baffled at the moment it went on 2 trips when it was a bit difficult to start but it operated really well no misfiring etc and rrestarted when hot. I am a bit dubious it is the crank shaft sensor. I am concerned it is the security key module but I was assured if it cranked it would not do that.
I would like to say how kind you are to afford the time to reply to me thank you so much.
Regards
Noel
