Thread: help needed
Old May 12, 2021 | 10:58 AM
zip439's Avatar
zip439
Default Re: help needed
Originally Posted by UrbanE
sometimes it’s hard to find the 8 rib pulley. I ordered one for the SRT and received the 6 rib so I just swapped the pulley
it takes 10 min tops to change them out
You may never get that pulley removed with a hand wrench; Use an impact wrench and it will loosen the nut to remove the pulley.
An easy check of your alternator at your home; simple place a volt meter selected to AC voltage on the positive and negative terminals of your battery and with the car running if you get any AC voltage at all your alternator needs rebuilding or replacement. The auto parts store will check more than just that, but it is a quick easy test you can do with minimal tools at home.
