tried to send this before but is no longer available so here i come again:
from ads i learned that the konis come with some fittings. like this:
https://www.ebay.com/itm/Koni-8041-1...-/142491846673
and the other:
https://www.summitracing.com/parts/kon-8041-1228spt
as you can see, 1 shows certain parts and the other, different. 1 has the rubber spacer, but not the other 1. and we need both to have it because the diameter of the shaft is larger, from what i have heard. but then the ad says: "
Image is a representation of this item. Actual item may vary. " go figure !
i hope some1 can help to unravel this mystery.
