phil alvirez
thank you for your input.
regarding: "
and drill out the metal part of the dust cover to fit the larger diameter of the Koni's. ",
what dust cover you are talking about? is that sort of large washer that is seen in the pic of post 9?
and the post you attached is very illustrating. so many details...
thanks again.
this?
and what is the diameter of the konis?
That photo is of an aftermarket shock so the dust cover and top is designed differently. It would be the area below the washer. The top of the black plastic dust cover has a rubber piece and underneath that is a metal cup / collar.
Not sure on the size, but it is a little bit bigger. You can use a drill or a dremel to open it up larger. It will be really obvious when you take it apart and fit it to the Koni's. A vise to help get those pieces off makes things a lot easier.
