Old May 23, 2021 | 02:48 PM
zip439's Avatar
zip439
Default Re: Changed conductor plate now no start
Originally Posted by Tminard
I just changed the conductor plate
Now car won't start. All electrical components work just wont do anything when u turn the key
You need to clear all the codes that have been set; That scan must get into the transmission/Mercedes codes, a common generic OBD II scanner will not go deep enough. Clear all your codes then try to start the car; still no go re check any set codes.
