Thread: Dome light
Old May 28, 2021 | 09:40 AM
Doc78's Avatar
Doc78
Default Re: Dome light
Hi all another issue with SRT.
I posted on another thread about my fog lights not staying lit after I get out of the car anymore.
I also have the map lights not coming on when I get out.
they come on when I hit the unlock button on the fob and stay on until I start the car.
they will come on when I open the door and the dome light works.
when I park and turn the headlights off and get ready to get out nothing.
I do have a battle with water in the trunk from a leak around the fuel inlet.
pneumatic locks work great.
I do have the siren removed right now for repair/replace.
I also have my trunk light removed due to blowing the top left top convertible cylinder this week.
Could I just have the switches in the wrong position some how?
Any help is greatly appreciated.
UPDATE:
Found the problem. CPS and the 18 pin connector under the cargo compartment on the passenger side had lots of water damage. I ordered a new CPS from needswings and Needswings stated they have a rebuild kit for the 18 pin connector. Mine had a few pins broken off due to corrosion. I found my answer on this forum with some reading found that 180 had mentioned that the CPS module controls that part of the fog lamps and map lights when you turn off the car. I will update again when parts come in and final repairs are made.
Thanks again for all those that help here. It is truly what makes this place great!
