Old May 29, 2021 | 04:13 PM
mrtbq1's Avatar
mrtbq1
Default Re: Speedometer/Odometer and ABS, Cruise Control not working
Thanks. I took it into Christian Brothers Automotive in South Tulsa because they have the equipment to test and get the codes. I've requested those codes and should have them by this coming Tuesday June 1st. When I do, I'll reply again with all of them. Currently I have a BRAKE light that stays on all the time. Brakes have been inspected and are working great as well as the emergency brake. On the Speedometer at the bottom the number 730 is indicated. The ABS light, and BAS ESP lights are on all the time. The fin is stuck in the up position and the two position control for it has a flashing red light. The car skidding symbol in the middle of the speedometer does not light up and the two position control switch does not turn it on. The cruise control does not turn on. The speedometer indicates 0 at all times and the odometer never changes. The brake wear indicator light is always on as well at the Check Engine light. All of these were checked by Christian Brothers and the system was either fine or they could not find out how to get the lights off and the other indicators working. I have replaced the RCM with a brand new one and there is no effect.
Again as soon as I have the error codes I'll post them. Thanks for any help you can give.
