Old May 29, 2021 | 05:39 PM
zip439's Avatar
zip439
Default Re: Speedometer/Odometer and ABS, Cruise Control not working
Some of your problems seem to be related to the brake light switch which is located at the top of the brake peddle under the drivers dash. Be certain all the fuses have been check in the fuse box behind the panel at the end of the dash, drivers side. When the door is open you can see a couple plastic screws which are turned to remove the panel. If Christian Brothers has a correct scan tool they should get a set code indicating the brake light switch problem.
