Old May 29, 2021 | 06:42 PM
zip439's Avatar
zip439
Default Re: Speedometer/Odometer and ABS, Cruise Control not working
Originally Posted by mrtbq1
Thanks. Battery was just replaced. Yes I got the car from my elderly father with the problems. He had just replaced the battery and everything had been working perfect. After the replacement he noticed all of the problems. Yes, Christian Brothers tested all fuses.
I just googled Christian Brothers Automotive in South Tulsa. They may be a fine general garage, but I doubt they have the experience necessary to deal with the Crossfire. An experienced European independent repair shop who specializes in Mercedes is really where you want to be. The Crossfire is basically a Mercedes. It was built in Germany and has the mechanics and much of the electronic of a 2004 SLK 320. The parts are interchangeable except for the body.
Can you drive the car, or was it towed to Christian Brothers? Is it an automatic transmission (I assumed it was) or a stick? If you had the car towed to Christian Brothers then everything pizzaguy says makes sense.
