Old May 30, 2021 | 12:53 AM
zip439's Avatar
zip439
Default Re: Limp mode / misfire help
You can use the search box in the upper right corner of this forum to search for limp mode, hesitates and shacking, misfire etc and find many different possibilities. When the check engine light goes on it will set a code; read the code and start your investigation based on the code or codes. Vacuum leaks are often a cause of your symptoms, or the throttle body.
GET THE NUMBERED CODE; not just some wordy explanation as to what the code means. We need the exact numbered code or codes.
