Old Jun 1, 2021 | 10:54 AM
Doc78's Avatar
Doc78
Default Re: Spoiler has no power and electric seats don’t work.. HELP 😭
Hi,
I will try to help.
1) Are you using your FOB to lock the doors?
2) Are the doors locking when you use the fob?
3) What fuses did you change that blew? This will help us determine issues. If the card is no longer present in your fuse box under the hood or dash there is a thread here that will lead you to the fuse numbers.
4) I would check under your seat and see if the floor is wet.
5) open your trunk and open the cover to your jack. Looking at the foam black pieces stick a piece of paper all the way down till you hit bottom down the far right side of the black foam pieces and if the paper comes back wet then we have a few more answers and can help with that issue as well.
There are people way batter at this than I am but this will get everyone started.
