Bob0121
ok so here’s a little update I wasn’t to fussed about the alarm hence didn’t attempt to disconnect the siren but I will do it once everything else is sorted.
my main concern is the electric seats and rear spoiler so today I ripped out the panel under the steering and pulled out the seat relay as I couldn’t hear it click while pressing the seat controls I knew the relay was faulty so I opened up the relay and saw 4 solders which were cracked so I decided to refresh all of them at the same time once done I put back the relay and the electric seats came back to life 🤪
now I need to sort the spoiler out but don’t know where to start as there’s no power showing on the manual switch (I’m told it’s meant to flash red when there’s a issue) but mine is dead... does the bcm control/give power to the spoiler? Or would it be a separate relay/fuse? also on the centre console where the manual spoiler button is all the other buttons flash red when pressed apart from the spoiler one which don’t make sense 🤷♀️
In you manual on page 230 it states fuse 20 controls your spoiler. Id check that fuse it is located above the two green 30 AMP in your picture. It is the 10 AMP red one.
