Old Jun 10, 2021 | 10:08 AM
ZERACER
Default Re: Replacing Skreem Module Worth It?
If it tries to start three times and then nothing it is probably the screem. If you disconnect the negative side of the battery for a minute and then reconnect it should repeat the three tries then nothing again. If not it is probably the RCM, a cheap and easy fix.
