JoeO
I changed out antifreeze and thermostat today using Zerex G05 premixed and Bosch.
I cannot locate the minimum and maximum marks usually found on reservoirs.
i have the level about halfway up.
any ideas on this ?
Inside the reservoir at the rear you can see a pillar sticking up, the coolant is correct at that height.
Basically the same level as the bottom of the black cover on the reservoir.
