Old Jun 14, 2021 | 12:43 PM
Doc78's Avatar
Doc78
Default Re: Driver’s side door lock
Originally Posted by Davidod
The driver’s door does not work with the switch on the dash but does work with the key.
180 is spot on. It is worth your while to look in the storage compartment under the cargo compartment(trunk) for water! Passenger side is the focus..
This causes all kinds of issues and 180 did a great thread on how to stop the water intrusion. I just completed this repair by following the instructions and no more issues.
My 05 is garage kept and came from southern California so not a whole lot of water other than washing it. My SRT had about two inches of water in the passenger side which corroded my CPS pump connector to the point that all kind of interesting things were going on with her. (I listed the malfunctions in the thread below)
When I disconnected my CPS three of the 18 pins came with the connector. I have electronics experience so I decided to repair my 18 pin connector and I was successful!
I will place the thread location below to help you with that if the CPS is your culprit.
https://www.crossfireforum.org/forum...ighlight=water
Like 180 said I hope is that the line just cracked on your drivers side but worth the time and effort to check it out.
Hope I helped
