Strange brake lights, BAS/ESP light, ABS reader?
Hello ,
My 04 crossfire has recently developed an issue. The ESP/BAS like came on and the rear brake lights are acting strange... the drivers side never comes on and the 3rd brake and pas side are on at all times the time.
Which style of scanner is required to check the ABS/ESP/BAS light codes ?
I did replace the battery recently but I have performed the "reset procedure " multiple times since then to no avail. I'm going to swap the brake light relay and do the TPMS disable in the meantime. Next is go over the entire brake system and check the ABS sensors, ETC.
Any tips or similar experiences with this ?
Thanks in advance
