Re: Whirring noise when accelerator is pressed
Thanks for the replies. I don't think it's a bearing because revving the engine doesn't make it happen. It makes the noise when starting up from cold and when the car is in gear and the engine is put under load, if you take your foot off the accelerator the noise stops. It sounds like an electric motor, similar to a fuel pump noise but it's under the bonnet somewhere.
