Old Jun 29, 2021 | 09:58 PM
  #7187 (permalink)
Valk
A couple weeks ago at our Crossfire fun in the Ozarks event we had a "Tech Day"
I had my idler pulley and serpentine belt replaced.
I also had a fan mod installed which is a toggle switch that you can use to manually turn on the cooling fan to run at top speed.
This is for extra cooing of the engine temp while sitting in traffic or parked with the AC on on a hot day.
I also had my new Alpine stereo installed and now wired directly to the existing stock amp to provide the full 4 channel sound our cars are capable of.
The stock stereo and the harness only use 2 channels and even if you install a replacement stereo if you simply use the existing harness you are still only using 2 channels of a 4 channel amp.
Using all 4 channels of the amp provides a much higher quality sound from all the speakers and allows the sub woofers behind the seats to provide much more output.
I have a Roadster and I can here the music fine on the highway with the top down now !!
I highly recommend this particular stereo too
