Re: The Chevy Vega - '74 GT
~ Hydraulic TOB finally bled. Shifts into gear properly. Runs and drives now. Drove it out of the garage to clean underneath and backed it back into its spot.
~ Passes the "Heidelberg Test"....printers know what this means...you can balance a nickle on its side with the motor idling...smoothe.
~ Speedo cable exits the speedometer in a way that the newer"77" air conditioning plenum is in the way. We will bore a hole through the plastic plenum and make a sealed tunnel through it with PVC to run the speedo cable through.
~ Seat rail mods to the Pontiac G5 seats is now taking place. Theyre a little wider than the original Vega seats, but we mocked up the door with the seat in place and the door closes properly.
