Old Jul 15, 2021 | 10:57 AM
Deepsea21's Avatar
Deepsea21
Default Re: Difference between bad Camshaft and Crankshaft position sensor symptoms
Symptoms are the same... No start although generally the crankshaft sensor goes before the camshaft sensor as it is located in a hotter area of the engine. Sometimes when the crankshaft sensor starts to fail the car will die while driving but then you'll be able to get it started again after it has cooled down. Crankshaft sensor is cheaper than the camshaft sensor. When you replace, go with Bosch... Not cheap crap that will fail right away.
