Old Jul 18, 2021 | 09:27 PM
GraphiteGhost
Default Re: Radiator replacement instructions
IF you do replace the water pump, make a cardboard template of the screws/bolts because there are various lengths of those holding the pump in place. You would not want a long screw/bolt going into a short hole that's for sure. About the cardboard template, as you remove one, place it in the position on the cardboard, and so on. You'll have a much quicker swap this way and not put the wrong one in any hole. Good luck!
