Old Jul 19, 2021 | 11:59 AM
srt6prbk's Avatar
srt6prbk
Default Re: fixed clutch delete pulley aluminum
just pull the clutch with heat, then align the pulley with the pin holes and tap the new pulley with soft strikes. I used a 1 inch thick rubber with small mallet. then install the pins carefully with the oem washer. then I use 2 drops of loctite 641. You should need the tune for a smooth idle
