Old Jul 30, 2021 | 05:09 PM
GraphiteGhost
Default Re: blinker will not turn off
Originally Posted by Swimman1
they just stay on ( not blinking). ? Did the switch thing and it is where it belongs. thanks. Did you ever have this problem ?
Hello, no never had this problem. Does the switch (light switch) work normally (except for this problem)? Far left rotation left side front and read park lamps, second position FROM left (right side marker lights), Center position all lights should be off but..... 4th position from left & turning switch to right (all park and marker lamps lit), and finally fifth position from left all lamps (including fog and high beams if activated)? I'll await your reply in case I didn't make myself clear. Thanks!
