Old Jul 30, 2021 | 05:22 PM
GraphiteGhost
Default Re: Upper Brake Light 2005 convertible
Hi Jeff, and Welcome! I see your a new member. You MUST read a few posts here about Chrysler and the Crossfire. They mostly will not be able to support your car and it may sit in the dealership (which we call mostly STEALERSHIPS). Chrysler and Mercedes Benz had a bad divorce, you'll find MB will snub their collective noses and refuse to work on your mostly parted SLK320 (if the N/A 3.2L, not the SRT-6). This forum will help you with repairs with some patience and well prosed posts about what your having a problem with. If beyond your abilities, an independent European mechanic can help with all the SLK320 compatible parts for your XF. If your able to be flexible, some members in your local area might be able to assist you with your car. Otherwise, Chrysler will bleed you dry if you let them. GOOD LUCK!
