Old Aug 2, 2021 | 05:59 PM
onehundred80
Default Re: Heater fan going full speed all the time
Originally Posted by Doc78
I think your problem lies in the blower motor resistor. I know you have changed it for a cheap one but I have gotten bad ones out of the box before. I have looked over the schematics on page 24-60 in the service manual and you have changed everything else but the motor and the wiring itself.
https://www.crossfireforum.org/forum...-resistor.html
This was an amazing write up that you turned into a PDF about 8 years ago it has the wire color and everything and the voltage you should have at them.
Good luck and keep us posted.
Thanks for the reply but the centre pin should give a voltage varying from 0 at position #0, approximately 2 volts at position #1, increasing incrementally to approximately 7 volts at position #5. Instead it gives a constant 12+ volts from position #0 to position #5 resulting in maximum revs from the fan. I get the same result from the original and the new regulator. The manual calls it a regulator not a resistor so I have followed the manuals name.
