Doc78
Do you have any codes? Is the BAS/ESP light on? I would pull the CLP/SSM pump and take a good look at those connections.
The more information you can give us the better we can assist.
Let us know what you discover. We will do what we can to help.
thank you very much for your reply.
When i disconnect and reconnect the battery die BAS/ESP light comes up but goes away after moving the car a little bit.
i tried two different OBD2 Scanner but got 0 error codes. i just ordered a micropod 2 witech. its being delivered from china so it might take some time.
when it arrives and i cant find the problem with the scanner im gonna pull out the locking pump and check the inside.
