Old Aug 5, 2021 | 09:41 AM
dedwards0323
Default Re: Removing CROSSFIRE emblem??? Chime in!
I would use a heat gun to warm the adhesive and then use a plastic prying tool like found in a set of interior trim removal tools to gently pry the letters off. I just did this to replace the Ford emblem on my F-150's tailgate. Worked perfectly. Only had to warm up the left over adhesive to remove it from the painted surface. I have a
plastic razor blade scraper"><span style=plastic razor blade scraper" /> plastic razor blade scraper">plastic razor blade scraper
for doing this type of stuff. Bought it off Amazon. Make sure to get one with the plastic razor blades if you're interested. Won't damage the painted surface.
