Old Aug 10, 2021 | 09:54 PM
MickeyD's Avatar
MickeyD
Default Re: No Crank, No Lights
Hello Doc78,
I did check the fuses and they were good. Also replace the main battery ground you mentioned about 10 months ago as that had caused some issues last year.
I did disconnect the battery before I removed and inspect the RCM for bad solder joints or burned components. None found. Everything was still dead and then about an hour later the alarm started going off as described.
RCM the mostly cause?
Mike
