Old Aug 10, 2021 | 11:43 PM
onehundred80
Default Re: Wiring conundrum
Originally Posted by Mr. Max
To make a long story short, the rats ate the wires under the driver-side fuse box and I'm soldering them back together. My problem is that there are two identical light green, no stipes wires. Using a river analogy. On one side of the river are 2 greens, one with voltage and one with no voltage (hot and not) on the other side of the river, I have the same situation, 2 greens, "hot" and "not". My thinking would be the "hot" wire on the north side of the river would go to the "not" wire on the south side of the river and the "hot" wire on the south side of the river would go to the "not" wire on the north side of the river. HELP!
Sometimes these small wires have barely noticeable coloured lines down them, visible at some points down the wire and not at others. I cannot see two green wires side by side.
Have you found the schematic of the fuse box?
