Old Aug 11, 2021 | 05:38 AM
Mr. Max's Avatar
Mr. Max
Default Re: Wiring conundrum
Sometimes these small wires have barely noticeable coloured lines down them, visible at some points down the wire and not at others. I cannot see two green wires side by side.
Have you found the schematic of the fuse box?
Thanks, OneHundred80, I can't see any difference on the wires. There might be one somewhere down the line but it is pretty hard to get "down the line." That Rat Bastard picked the worst possible place to sharpen his teeth. I've poured over the schematics to no avail. I think I'm pretty safe comparing the length of the wires, long on one side of the break to short on the other side of the break and vice versa. The rat would have had to take a section out for that not to work. However, I thought I CYA and throw it out to you all before I proceeded with wire surgery. Thanks again, Max
