Mr. Max
To make a long story short, the rats ate the wires under the driver-side fuse box and I'm soldering them back together. My problem is that there are two identical light green, no stipes wires. Using a river analogy. On one side of the river are 2 greens, one with voltage and one with no voltage (hot and not) on the other side of the river, I have the same situation, 2 greens, "hot" and "not". My thinking would be the "hot" wire on the north side of the river would go to the "not" wire on the south side of the river and the "hot" wire on the south side of the river would go to the "not" hot wire on the north side of the river. HELP!
First off I'm very sorry to hear about that happening.
There are actually two fuse box panels on the driver side. You have the fuses accessed through the side of the dash on the driver side. That is part of the Illumination Control Module. Looking at the 2007 service manual the wiring pin outs, color codes, and purpose is on pages 8W-080-35/36. I didn't see any light green listed.
The second fuse block which is under the hood on the driver side is the Underhood Accessory fuse block. The fuse list, wire colors, and funtion are on pages 8w-10-3. I didn't see light green only wires listed here either.
There are located there as well.
