Old Aug 11, 2021 | 08:18 PM
Mr. Max's Avatar
Mr. Max
Smile Re: Wiring conundrum
Originally Posted by Toolman
I happen to have a used spare Illumination Module with pig tails. I pulled it out to check the wire colors. It has three light green wires with white strips and a single light green wire with no color strip. The all green wire is listed in the Illumination Control Module B connector pin out diagram (provided above). It's # 14 pin connector with a wire color of DG which stands for Dark Green. It certainly looks light green to me. It's function is Fused Illumination Control Module Output. LG would be for Light Green. There are no other green wire color codes in the wire color code chart.
WOW! Talk about an "above and beyond the call of duty" answer. I didn't expect such a fantastic reply. Thank you, Toolman, Jeff (Mr. MAX)
