I will give you what I have from the service manual. Pages 21-220 through 224.
I highly recommend you downloading the service manual from the forum. I placed a link below so you can find it. It has illustrations for the mentioned screws and bolt removals.
https://www.crossfireforum.org/forum...ollection.html
1. Disconnect the negative battery cable.
2. Remove the propeller shaft. (Refer to 3 - DIFFERENTIAL & DRIVELINE/PROPELLER SHAFT - REMOVAL).
3. Remove the lower splash shield screws (1) and the
lower splash shield.
4. Remove the transmission ground bolt (1) and
cable.
21 - 220 AUTOMATIC - NAG1 SERVICE INFORMATION ZH
5. Place a suitable drain pan beneath the transmission
drain.
6. Remove the transmission drain plug (2) and drain
the transmission.
7. Disconnect the transmission shift selector rod (1).
ZH AUTOMATIC - NAG1 SERVICE INFORMATION 21 - 221
8. Disconnect the transmission oil cooler line banjo fittings
(1) from the left and right sides of the tranmission
housing.
9. Remove the transmission oil cooler line retainer
bolts (1) from the left and right side of the engine
lower oil pan.
21 - 222 AUTOMATIC - NAG1 SERVICE INFORMATION ZH
10. Remove the torque converter access cover (1).
Note: Rotate the engine at the vibration damper
bolt.
11. Remove the torque converter bolts (2).
12. Disconnect and remove the oxygen sensor harness
connectors (1)
13. Remove the heat shield bolts (2) and the heat
shield
ZH AUTOMATIC - NAG1 SERVICE INFORMATION 21 - 223
14. Disconnect the transmission control harness connector
(2).
15. Position a transmission jack under the transmission
oil pan rail.
16. Remove the starter. (Refer to 8 - ELECTRICAL/
STARTING/STARTER MOTOR - REMOVAL).
17. Remove the transmission to engine retaining
bolts.
18. Lower and remove the transmission from the
vehicle.
DISASSEMBLY
