ORL-XFR
Mine did that when it was just short of 3 years old. Ended up being the fuel pump - got it replaced under warranty and it has never happened again.
It looks like post number two was correct. I had the same symptoms as Rupert but had already installed a BOScH fuel filter as well as sensors and repaired RCM. I just had a new fuel pump installed and now it is holding pressure When the key is turned off. The check valve must be in the fuel pump itself rather than in the filter as suggested in a previous reply.
