Old Aug 16, 2021 | 03:26 PM
Egyorko's Avatar
Egyorko
Default Re: Run-Start Circuit Failure Leads to Top Nonfunctioning
I also realized that the short could be in one of several outputs from the BCM that is sourced internally from pin 58 (Run-Start). I’m thinking this might be the case, since the BCM circuit card that came with the car was fried (see below - someone may have used a bigger fuse instead of addressing the issue). If anyone knows what outputs may be sourced from pin 58 internal to the BCM that would be helpful.
