Old Aug 16, 2021 | 05:44 PM
GraphiteGhost
Default Re: Run-Start Circuit Failure Leads to Top Nonfunctioning
Originally Posted by Egyorko
I also realized that the short could be in one of several outputs from the BCM that is sourced internally from pin 58 (Run-Start). I’m thinking this might be the case, since the BCM circuit card that came with the car was fried (see below - someone may have used a bigger fuse instead of addressing the issue). If anyone knows what outputs may be sourced from pin 58 internal to the BCM that would be helpful.
Have you downloaded the service manual and perused the BCM system circuit diagrams? The pinouts will locate the circuits for you, you can build from there the answers to your questions. Looks like quite a few pins are effected. The manual is free to download and available with a search of the site. Good luck!
