Old Aug 17, 2021 | 01:58 PM
GraphiteGhost
Default Re: Horn is very quiet
There are two horns, a high note one and a low note one. There are many horn kits available at auto parts stores (with both, for balance) so if you replace one you might consider the set in a kit. There are a few 'salvage' yard links within the forum that might have the crossfire horn set for sale (if you wish the OEM set a requirement) Good luck!
Am guessing you already troubleshot the horns, a few simple things outlined here already. Just remember, there are 2 horns in the crossfire, one high, one low. Together they are loud, if only one working it sounds 'funny'. You can check if 12 volts are getting to each, easily.
