Re: Cable tonneau flap side wanted....
I don't believe these are available any longer. I replaced both of mine a number of years ago as both got hung up in the cable sleeve. My suggestion would be to disconnect the cable and take it to a shop that repairs convertible tops and see if they can make one or two for you. Another option would be a salvage yard but you may run into the same problem. If/when you are able to find a replacement be sure to use a cable lube tool and cable lube to lubricate heavily before you re-install. Good luck!
PJ
