Old Aug 19, 2021 | 03:15 PM
Ronman's Avatar
Ronman
Default Re: Key Fob not unlocking doors - need troubleshooting steps
Originally Posted by Scotto97
Well I replaced the CLP/SSM and have the same issues. So it's not the culprit.
I'm also hearing a faint but fast crunching or clicking sound from near the center air vents on occasion.
What should I replace next?
That clicking sound might be from the BCM. So disconnect battery, remove BCM and open it up and check the board to see if anything is burned or looks like it. If that is the case then you need to find a used one that preferably has the same part number and HW and SW on it as the one you have. I also think make sure it is for the same transmission manual/auto but not 100% sure on that one.
