Old Aug 20, 2021 | 11:34 AM
Ronman's Avatar
Ronman
Default Re: Spoiler Stuck in UP position
Originally Posted by Sixkay
Hello, thanks for the replies zip and doc. i have a small update. i bought a new Varta 77AH 780A Battery to be 100% sure its not that. it didnt change anything. i also got my drb3 emulator which i think i managed to setup right. im not able to connect to the body control module or the central locking pump. i am getting "NO Response from BCM pin 1" and "NO Response from CLP pin 1". i recorded a short video of the emulator.
https://www.youtube.com/watch?v=5c6cuAkjh4k
i am able to connect and read parts of the car like the engine but other parts fail. is it possible to screw up the setup that only half of the functions work? how should i proceed now?
@zip: the wing parts/gears look all good to me. there is also no visible water residue in the trunk area. but i have to say that i still have not unplugged the locking pump and opened it up.
I've had that happen to me with other modules with the DRB 3 emulator. Try disconnecting your battery for 30 minutes and try again. If that doesn't work then follow what the service manual says which will be either the modules are defective, clean/repair connectors etc.
